Parting out 1987 325e, lots of stuff, pics inside
14
boston
And the engine bay:
Ok so far these are the parts I’ve pulled and their pics. If you need more detailed pics of any part please let me know. In a few more days I should have the engine bay and power train disassembled. I will be taking apart the interior and trim based on demand. Everything that I’ve listed works perfectly. The car has 210K miles and I’m going to assume that all equipment is original.
Master cylinder: $50
Alternator: $40
Thermostat housing with 80 degree thermostat: $25
Throttle body: $30
Power steering pump: $50
Starter: $75
Idle Control Valve: $25
Fan Clutch: $40
Power steering reservoir: $10
Windshield washer pump: $15
Fan Clutch: $50
Water pump (New only about 300 miles on it): $10
Air flow meter: $50
Intake manifold w/ fuel rail/pressure regulator/injectors: ??? Negotiable
Radiator: $30
Crankshaft damper and 3-1 pulley: $10
Valve cover: $25
And also a complete set of cooling hoses with about 300 miles on them, in perfect condition. New they cost me $110. Anyone want them? $10??
email: alperin@wpi.edu
phone: 617 964 6042 ask for Yan
14
boston
Just tore up the interior:
All the switches, ecu, abs computer, idle computer, cluster(cracked but works perfectly), door handles, consoles, and ebrake boot:
Close up of the switches:
The door panels:
And the dash board, no cracks:
What's left: Anyone want anything from here?
Also available stock shift knob in perfect condition and pretty worn steering wheel.
boston e30
14
boston
Here’s the head (2.7 L 210,000 miles) $175 shipped:
No cracked or bent valves, never found any water mixed with oil. Car was running great with this head. Could use a cleaning and valve adjustment.
epj3
7,370
Lancaster, PA
Sorry dude but you're asking way to much for some of those parts... an ETA head with 210k miles is worth maybe $100 shipped. Fedex will cost about $20 to ship the head.
14
boston
#14
LadyJustin said:
What do you want for the door panels? Are they perfect? Are you selling the wheels?
The tan interior door panels right? The drivers side door panel shows wear on the arm rest, and both map bins are slightly dirty. Also the passenger side panel is missing the little black cap on the armrest where the sidemirror control is on the drivers side. Looking to get $90 shipped for all four.
Ben
Active Member
576
NY
#15
epj3 said:
Idle control valve from an ETA won't work on an "I" - air flow meter is the same as far as i know, check www.realoem.com first.
I think your right. its a different size engine, so it probably wont work. even if it did, theyre probably stock, and will fail soon.
